Hi, hopefully someone can provide answers regarding the V9 evaluation
If the server must access internet via a proxy server with username & password, are the steps to install still the same as V8? i.e., create a local administrator account matching the proxy username & password, logon as the new local admin, configure IE to use proxy, install IEM and then set the service to run as the username & password.
With regards to this username & password, am I able to use the matching AD user?
Are we still able to install the V9 evaluation using another machine with internet access and generate a masthead file?
BTW, I believe you’re in Singapore. So please contact me via @vtdarryl (twitter) if you would like to be put in touch with a local IEM SME - where you can be provided a trial license for longer periods (essentially like production software)
Current workaround is to run BESAdmin command to set the proxy username and password as mentioned in the documentation. After that, set the Proxy key value to :@<hostname/IP>:.
IEM services can still run as SYSTEM account and no other configuration required, as far as I can tell.
