I have using IBM Bigfix Power Management 9.2.6v, in that if I create a power consumption policy and applied some windows 10 machines. it is not applied in the client machines.
Is this Power profile policy can support Windows 8.1 & 10 Operating System?
Thanks,
Nagaraj.
You can find that out by looking at the relevance code? or share the Relevance code for the policy you created, I can help you out.
fermt
October 25, 2016, 7:32pm
3
This is the wizard which i set the value based on bigfix console
This setting (Computer standby = 20 minutes) mean the setting is not apply on windows OS 8.1 & 10 system.
IBM Bigfix Power Consumption policy wizard support to Windows 8.1 & 10 machines?
Thanks,
Nagaraj.
lowmztr
October 27, 2016, 12:38pm
6
An RFE has been entered to have Power Management updated to include the latest Mac and Windows OS’s. Please vote of it.
http://www.ibm.com/developerworks/rfe/execute?use_case=viewRfe&CR_ID=83305
Power Management End of support is at April 2017 and that might be one of the reason!
Must have missed that announcement. Would you be able to a link to it?
end of support is for only v9.0.x.
v9.2 is coming with bigfix lifecycle 9.2, isn’t it ?
Nagaraj
November 29, 2016, 12:48pm
11
What about 9.5.2 Power management in Big-fix life-cycle management?
Thanks,
Nagaraj.
