IBM BigFix Compliance PCI Add-on
Security Configuration Management (SCM)
The IBM BigFix Compliance team has updated the content for the Payment Card Industry Data Security Standard (PCI DSS) checklist for Microsoft IIS 7.
Updated Site:
PCI DSS Checklist for MS IIS, version 5
*Site version is provided for air-gap customers.
Changelist:
Removal of an unnecessary task that is used for internal testing.
Actions to Take:
If you are using custom sites, ensure that you have the latest content that is available from the updated PCI DSS Checklist for MS IIS site. You can apply the update to the custom sites by using either of the following methods:
- If the custom site is not a copy of the external site, manually remove the task called TestEnvironment from the custom site.
Note: This task must not be deployed on a production environment. - If the custom site is a copy of the entire external site, use the Synchronize Custom Checks wizard and do a Detailed Targeted Scan against the custom and external sites.
– The IBM BigFix Compliance PCI Add-on team
