Can someone check on this We are on 9.5.8 version which is latest one.
When i try to get in IEM CLI it allows me to get in but whenever i query any thing its showing following error.
iem GET Operators No cached session exists. Use the command ‘iem login’ to reauthenticate.
Like Alan above said, the CLI requires you to login first. You can login by typing iem login and entering your credentials. Your original command should work after that.
