Looking for a cross platform way to determine if a client is 32 bit or 64 bit. Is there a bit o relevance that does this out of box?
You mean the host operating system?
Q: x64 of operating system
A: False
Will that work on linux and solaris?
For windows, we had been using:
(not exists (value of variable âPROCESSOR_ARCHITECTUREâ of environment) whose (it as string as lowercase contains â64â).
âx64 of operating systemâ will work on Windows 6.0 and Mac.
âia64 of operating systemâ will work on Windows 7.0 . (True if Itanium)
âarchitecture of operating systemâ will work on Linux 4.1, HP-Unix 4.1, Mac 6.0, AIX 4.1, Solaris 4.1 . You need to match this result against a known string. For example in our redhat content we use 'architecture of operating system = âx86_64â. The exact string to check for depends on the specific flavor of operating system.
Note I pulled all the version compatibility information from the inspector search utility: http://support.bigfix.com/inspectorsearch/inspector_search.html
Jesse
Is there any kind of initiative to make inspectors OS agnostic? Seems like a standard way to query for things would be a great selling point.
Generally wherever we can we will make the inspectors cross platform, but we are limited by the APIs made available by the OS vendor.
I guess I am not following. The OS vendor supplies the APIâs but wouldnât the inspector isolate the user from the API? Couldnât an inspector called, for instance, âarchitecture of operating systemâ provide a value of x86, x64, i64 or a64 by querying those apiâs and manipulating the data?
Sorry if I am not understanding, but it just seems like all the information is there, itâs just a matter of consistent presentation. Writing queries would be a world easier if properites were kept common.
