HI,
I have an issue while I am using the bigfix relevance to sort data output, if I am writing the relevance code with “it” clause then the data that is generated is in sorted format but as soon as I added “it” clause the data become distorted, let me use one example:-
Relevance clause for all rpm packages installed:-
Without “it” clause data is sorted in alphabetic order
Q: unique values of names of packages of rpm
A: BESAgent
A: BESRelay
A: NetworkManager
A: NetworkManager-initscripts-updown
A: NetworkManager-libnm
A: NetworkManager-team
A: NetworkManager-tui
A: WALinuxAgent
A: WALinuxAgent-udev
A: abrt
A: abrt-addon-ccpp
A: abrt-addon-coredump-helper
A: abrt-addon-kerneloops
A: abrt-addon-pstoreoops
A: abrt-addon-vmcore
A: abrt-addon-xorg
A: abrt-cli
A: abrt-console-notification
A: abrt-dbus -
While getting the output with it clause it is all distorted
Q: (unique values of names of it) of packages of rpm
A: perl-perlfaq
A: device-mapper-event
A: grub2-tools-efi
A: abrt-tui
A: rust-srpm-macros
A: libsepol-devel
A: mariadb-connector-c
A: libreport-plugin-mailx
A: mdadm
A: ocaml-srpm-macros
A: perl-Mozilla-CA
A: authselect
A: publicsuffix-list-dafsa
A: python2-requests
A: pygobject2
A: dyninst
A: net-tools
A: cups-libs
Now If I have to add more properties to it like version then I have to ad “it clause” and as soon “it” clause is added the output data is distorted, do we have a way to get the data sorted in relevance output? This sorting is not impacted because of “it” clause but do we have a way to sort the relevance output data?
