I’ve read through the platform API reference guide, but still do not figure out the right APIs for them. Could the platform API support the two functions? Is there any example? Thanks in advance.
You can download the Computer Remover command line tool which should let you remove the device from the database. As for the computer group, if it’s a manual group I’m not sure that can be changed from the COM API, but if it’s automatic you can update the relevance for the computer group to change it’s members.
I tried the Computer Remover command line tool to remove some existing device from TEM, but not successful, maybe I’m not using it correctly,please help advice. Below is the command I use to delete a device named “ldap’s MI-ONE Plus” from TEM database and the error I got.
