How to Install an Red Hat RPM package via Big Fix
BigFix is enabled with RHSM Plugin to patch the Red Hat Enterprise Servers,
However, how do I install a specific “rpm” package in a Linux server via Big Fix. Is there a way to install “rpm” by using the RHSM plugin and available CDN repository?
Greetings.
You can do this by utilizing taskID 401 ‘Yum command with RHSM download plugin - RHEL 7 - x86_64 - Server’.
-Matt
Good day.
Many Thanks Matt for the response . it works perfectly.
@Samsir firstly you need to enable RHSM plugin onto you main IBM BigFix server, later you can follow the steps which are been given into the link.
https://www.ibm.com/support/knowledgecenter/en/SS6MER_9.5.0/com.ibm.bigfix.patch.doc/Patch/Patch_RH/t_creating_rhsm_certificate_entitlement.html
