How to handle zero-length binary registry values?
(imported topic written by eammendola)
I am trying to create an analysis which captures a registry value, which is simple enough. However, I am having a problem with setting up a returned response if the data is a zero-length binary value.
In this example:
if
exists
(key
“HKEY_LOCAL_MACHINE\SOFTWARE\stuff\Install”
of
native registry)
and
exists
value
“SourceLocation”
of
key
of
native registry)
and
(value
“SourceLocation”
of
key
of
native registry
is not
then
(value
“SourceLocation”
of
key
of
native registry
as
string)
else
“No SourceLocation Data”
The code above works great for string values, but my value is REG_BINARY, so the double quotes looking for an empty string does not work. The zero-length binary value “exists”, but is not something (to my knowledge) I can return or compare, like a 1 or 0. If the value contains anything it will return that information, but if it is zero-length, a “Singular expression refers to nonexistent object.” is returned.
Is there a way around this?
Does this work?
value
“SourceLocation”
of
key
"HKEY_LOCAL_MACHINE\SOFTWARE\stuff\Install"
of
native registry
as
string
) | “NoValue”)
(imported comment written by eammendola)
That does in fact work. Thanks!
You are welcome.
It took me quite a long time to figure out how to use the “|”.
Here is an example of an Analysis Property doing it the “hard” way:
http://bigfix.me/relevance/details/2998470
Here is the exact same example the “easy” way:
http://bigfix.me/relevance/details/2998536
