how to get regapp property list using fixlet debugger
i am using fixlet debugger to use (names of it) of REGAPPS this displays list of apps on the server and (names of it, versions of it) of regapps this displays app name and its corresponding versions, how to get list of other properties of regapps? other than Name, version etc?
Thanks,
AR
You can also pull values from the version blocks from the regapps
(names of it, versions of it, values "FileDescription" of version blocks of it) of regapps
For the life of me I can’t recall where I found out there was a FileDescription but I’ll keep digging. Some info that might help https://developer.bigfix.com/relevance/reference/file-version-block.html
Hi @SLB,
Thank you, i tried (structures of it) of SMBIOS and got result as below with available properties, not sure if we have anything like this for regapps
Current Selection Evaluates To:
Error: Expression evaluates to an unrepresentable object of type ā€œsmbios structureā€. Available properties are:
hexadecimals of : string
integer values of : smbios value
integers of : integer
length of : integer
name of : string
string values of : smbios value
strings of : string
type of : integer
Evaluation time: 14.257 ms
There is an inspector search that you may find of use. https://developer.bigfix.com/relevance/search/?query=regapp&platform=windows
There is also this that gives additional info about the regapp inspector (this is probably where I found out about the FileDescription approach) . https://support.bigfix.com/cgi-bin/inspectorsearch/single_inspector.cgi?cpx=c&keyphrase=regapp+%26lt%3Bstring%26gt%3B&type=application&win=&client=1
You can also introspect properties in the fixlet debugger, eg for your SMBIOS example
Q: properties of result types of properties "structures" of result types of properties "smbios"
A: name of <smbios structure>: string
A: length of <smbios structure>: integer
A: type of <smbios structure>: integer
A: values of <smbios structure>: smbios value
A: values <string> of <smbios structure>: smbios value
A: integer values <string> of <smbios structure>: smbios value
A: string values <string> of <smbios structure>: smbios value
A: integers <string> of <smbios structure>: integer
A: strings <string> of <smbios structure>: string
A: hexadecimals <string> of <smbios structure>: string
T: 0.913 ms
I: plural property
Hi @SLB,
Yes, SMBIOS is listing all properties and not regapps, does regapps has only 4 properties? as i could find only 3, not sure how to find all other properties, and [regapps] is not giving much detail or examples
Name
Description
Version
Size
Regapps returns an ā€˜application’ type, so check for properties of type ā€œapplicationā€
Hi @JasonWalker, thank you! i was not able to get the whole list of headers! if you happen to know the exact command would help! TIA
AR
properties of type "application"
Or check the link I posted for the docs page
thank you @JasonWalker
