(imported topic written by dnlongen91)
I am trying to add some custom action logic to a fixlet to update QuickTime Player. The scenario is this: if QuickTime is not in use on the system, I can safely upgrade it without interrupting the user. However if QuickTime is in use, I want to alert the user that the upgrade will kill any running instances of the player.
It is easy enough to check for the standalone player:
If {(exists running application whose (name of it as lowercase is "quicktimeplayer.exe) or exists running application whose (name of it as lowercase is “itunes.exe”))}
// warn the user
else
// run silently
Is there a way to look for a running application iexplore.exe that has a handle to qtplugin.ocx? Is there an inspector that can see files that a running application has loaded?
