I did try %22 before based upon this posting I found on the site http://forum.bigfix.com/viewtopic.php?id=635, however this does not seem to work. I should get False answer to the following, but I am getting True.
q: not exists lines containing “%22bGroupActivate%22=dword:00000000” of file “XYZ.reg” of folder (“C:\Program Files (x86)\ABC”)
You relevance is correctly escaping the quotes. I think you have a different problem. Are you sure a line containing exactly that string exists in XYZ.reg?
Thanks Jesse, checked in relevance debugger, lines in a reg file are not being read. I have modified the relevance based upon date modified for the file. Thanks for replying…
Thanks Boyd, changing it to ANSI from default Unicode format seems to work for resolving with Relevance Debugger. Most likely I am not going to change the reg file encolding format as the file is part of an application directory and will need to consult the App Dev team. I was able to change the relevance code based upon creation date, i.e. (now - creation time of file “z:\XYZ.reg” > 60*day)
