Hello,
i want to do an In Place Upgrade for windows 10, however in BigFix i dont see the option imaging in System lifecycle.
i have a laptop that is 1909 and lower and i want to upgrade them to win 10 22h2
could you advise pls ?
Hello,
Hello,
you can find the task for Windows in-place upgrade in BigFix OSD site (“OS Deployment and Bare Metal Imaging”) that is part of Lifecycle, and it’s documented at this link → Installing Windows 10/11 or Windows Server using in-place upgrade
Thanks.
Sergio
BigFix OSD L3 team
@nad1402 which BigFix Licenses you have?
You can check if from the BigFix Console - BigFix Management - License Overview
