(imported topic written by nmilanese91)
I’m not able to write a string with char “è”. I’m trying to use the escape char %, but without success.
Q: “è”
A: %e8
T: 0.032 ms
Q: “%e8”
A: %e8
T: 0.034 ms
Anyone can help?
Thx
Q: “è”
A: %e8
T: 0.032 ms
Q: “%e8”
A: %e8
T: 0.034 ms
Anyone can help?
Thx
“%e8” = “è” so you are doing the right thing… but I don’t think that BigFix will try to display it (it will show the percent encoded version rather than displaying the character).
(imported comment written by nmilanese91)
Ben,
I’m on the right way, but it doesn’t work.
if I digit:
Q: “%65”
A: e
T: 0.045
So it doesn’t work with “%e8” (è) and with all the other italian chars like ò, à , ù, etc.
Is it in plan a fix for this.
Thx
