How to disable usb through bigfix.
First question would be how to disable this at the OS level. Once you figure that part out, its then how to translate that into a process you can deploy and maintain using Bigfix.
So first of all you need to investigate how to do this for your OS. If its Windows, check out http://woshub.com/how-to-disable-usb-drives-using-group-policy/ and https://www.isumsoft.com/windows-10/how-to-disable-use-of-usb-storage-devices-in-windows-10.html as possible approaches you can pursue
This should work for USB ports. May require a reboot.
regset β[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\USBSTOR]β βstartβ=dword:00000004
