(imported topic written by ebibibi91)
I changed web report using HTTPS instead of HTTP by http://support.bigfix.com/cgi-bin/kbdirect.pl?id=193 .
But now “BES Web Reports Server” service is not start correctly.
I want to know what is problem, but no information in eventlog nor web report log(http://support.bigfix.com/cgi-bin/kbdirect.pl?id=324).
How can I detect the problem? Is there more detailed log?
Thanks.
Hi ebibibi,
Does the Web Reports Server start if you change “_WebReports_HTTPServer_UseSSLFlag”=0?
If so, you might want to double check your path to your certificate and pem file and make sure all the settings look correct.
system
3
(imported comment written by ebibibi91)
Hi Ben Kus.
Thank you for your advice.
I found the problem about certification file.
Thanks.
