This says this isn’t a supported distro. When the OS is unrecognized you will get the kernel version. Internally a uname call is made and the /etc distro files are examined
CentOS should be supported. What version of the client are you using? I think its not 9.5 as I changed it to be clear this was a kernel version. If they are both Scientific then yeah that’s technically not a supported distro
