HI Jason,
let me understand this with a scenario, we are using manual relay selection, let say for a client the pri, sec, failover relays and root are not accessible for about a day. Now by this moment we will reach the max time of retry interval that is 2 hours.
- Now bigfix client will look for relays and root server every 2 hours? Is that the right understanding?
- After 2 hrs cycle will the retry be in the same order like it will look for pri then sec then failover and in the end root?
3.now in its next cycle of 2 hrs if the failover relay is accessible, then it should be able to report in the bigfix server using failover relay, correct?
- IF the agent is reporting using failover relay after how much interval later will it look for its pri and sec relay, Is it 6hrs?
Reason being we have this scenario is we are in azure infra with prod and DR, pri and sec relays in prod site and failover relay in DR, the plan is if the prod infra is down then all the vms will be up in DR and in this condition bigfix agent should be able to report via DR failover relay. And once the prod sites are back up then the same agents should be able to report back via the pri and sec relay.
