I am trying to get a Boolean value return if the repairstatus is 1 and the name is Tool1, but I am having no luck getting the logic worked out. Any help would be appreciated.
It looks a little malformed - I don’t see the closing tags for “sectools” or “wsconfig”. What have you tried so far?
When I test it, I get an error converting to XML. Do you get the same?
q: xml document of file "c:\temp\test.xml"
E: The expression could not be evaluated: XMLDomDocumentError: The following tags were not closed: wsconfig, sectools.
If you get the closing tags added correctly, I think the following should do what you need:
q: exists selects "wsconfig/sectools/sectool" whose ( (node value of child node of select "name" of it = "Tool1") of it AND node value of child node of select "repairStatus" of it = "1") of xml document of file "c:\temp\test.xml"
A: True
T: 0.811 ms
