We have a CSV file that contains a list of MAC Addresses and other data that we would like to retrieve and set as BES Client Properties. I have most of it working but I could use some help (and a sanity check) on the “Parameter for Email Address matching with parameter of MacAddress” section.
Goals:
- get a MAC Address and filter out VMNET bridges
- matching line in CVS against a MAC Address
- store values as a parameter
- set as client property
CSV File:
"A1-BC-23-45-D6-78","FirstName","LastName","FirstName.LastName@email.com","ID1Number","CompName","ID2Number","DeptName","UserName","TRUE","2015-11-02 08:06:27"
Parameter for MAC Address:
// Get MAC Address and filter out VMNET bridges
parameter "MacAddress"="{ (( mac address of it ) of adapters whose ( loopback of it = false AND address of it != "0.0.0.0" AND mac address of it as string does not start with "00-50-56-c0-00") of network) }"
Parameter for Email Address matching from known MAC Address
// Get Email Address using static Mac Address with static MAC Address
parameter "Email"="{ tuple string item 3 of (concatenation ", " of (substrings separated by "%22,%22" of (lines of file "data.csv" of (folder "C:\Users\username\Downloads\New folder\")) whose (it as string starts with ("%22A1-BC-23-45-D6-78%22,")))) }"
Not sure how to use escape brackets for relevance here and add the quotations to the parameter of MacAddress to match what’s in the CSV
// Attempt with Relevance substitution and not sure how to percent-encoding for a quotation mark on a parameter
parameter "Email"="{ tuple string item 3 of (concatenation ", " of (substrings separated by "%22,%22" of (lines of file "data.csv" of (folder "C:\Users\username\Downloads\New folder\")) whose (it as string starts with ( "{{parameter "MacAddress}")" )))) }"
Set client property
setting "Email_Address"="{parameter "Email" of action}" on "{parameter "action issue date" of action}" for client
