I am creating a custom report and I would like it to return a bunch of properties when it is executed. Every time I try to run it I get the error “The operator “equal” is not defined.” I’m using the excel plugin to get the code. Can anyone help me out?
( item 0 of it as string &
"$x$" & item 1 of it as string &
"$x$" & item 2 of it as string &
"$x$" & item 3 of it as string ) of ( (
if (exists result (item 0 of it, item 1 of it) and exists values of result (item 0 of it, item 1 of it) ) then (concatenation
"##" of values of result (item 0 of it, item 1 of it))
else (
"<none>")), (
if (exists result (item 0 of it, item 2 of it) and exists values of result (item 0 of it, item 2 of it) ) then (concatenation
"##" of values of result (item 0 of it, item 2 of it))
else (
"<none>")), (
if (exists result (item 0 of it, item 3 of it) and exists values of result (item 0 of it, item 3 of it) ) then (concatenation
"##" of values of result (item 0 of it, item 3 of it))
else (
"<none>")), (
if (exists result (item 0 of it, item 4 of it) and exists values of result (item 0 of it, item 4 of it) ) then (concatenation
"##" of values of result (item 0 of it, item 4 of it))
else (
"<none>"))) of ( elements of intersection of ( (sets of items 0 of (computers of it, values whose (it as lowercase contains
"troz") of it) of results of bes property
"Primary User")), bes property whose (name of it =
"MP3 Installed" and id of it = (2147495536, 118, 1)), bes property whose (name of it =
"Computer Name" and id of it = (2147495536, 4, 1)), bes property
"Installed Applications Aduit", bes property
"Current User Printers")
Thanks for the reply! I accepted your Netwrok Connect inventation but i’m not sure what that means. lol
What version of the BES Console for the Excel Connector 3.3.1 to work? I seem to be getting a lot of those not defined errors while using the Excel Connector.
This works:
(it) of ( (
else (
"Installed Applications Aduit")
But this doesn’t
(it) of ( (
else (
"Computer Name" and id of it = (2147495536, 4, 1)))
For some strange reason this part “id of it = (2147495536, 4, 1)” was causing the error. Once I removed all the id properties the error message went away.
