(imported topic written by imam91)
Hi All , i Want to create relevance / analysis from xml file , with output like this :
OS Win7 Installed : True
Service Pack Win7 Result : True
OS WinXP Installed : False
Patch Q2286198 Installed : False
Custom BigFix CustomC Installed : True
Sophos Anti-Virus 9.7 AVApp : True
The Result " true or false" is depend on the value of xml file @ Client
Below is sample xml file ,
- <EF:CurrentAssessment xmlns:EF=“ENDFORCE” version=“3.0” lastAssessment=“09/22/2011 02:20:19 PM” lastComplianceState=“partial”>
- <EF:Application type=“OS” name=“Win7” installed=“true”>
<EF:Capability type=“servicePack” name=“Win7” result=“true” />
</EF:Application>
<EF:Application type=“OS” name=“WinXP” installed=“false” />
<EF:Application type=“Patch” name=“Q2286198” installed=“false” />
<EF:Application type=“Custom” name=“BigFix CustomC” installed=“true” />
<EF:Application type=“AVApp” name=“Sophos Anti-Virus 9.7 AVApp” installed=“true” />
<EF:Application type=“Domain Security Applications” name=“HO - Domain Logon Check Domain Security ApplicationsC” installed=“true” />
</EF:CurrentAssessment>
I try this :
Q:preceding text of first “%22” of following text of firsts “<EF:Application type=“OS” name=“WinXP” installed” of lines of file “C:\temp\AssessmentResults.xml”
E: The operator “os” is not defined.
Q:lines whose (it contains “true”) of file “C:\temp\AssessmentResults.xml”
A: <EF:CurrentAssessment xmlns:EF=“ENDFORCE” version=“3.0” lastAssessment=“09/22/2011 02:20:19 PM” lastComplianceState=“partial”><EF:Application type=“OS” name=“Win7” installed=“true”><EF:Capability type=“servicePack” name=“Win7” result=“true”></EF:Capability></EF:Application><EF:Application type=“OS” name=“WinXP” installed=“false”></EF:Application><EF:Application type=“Patch” name=“Q2286198” installed=“false”></EF:Application><EF:Application type=“Custom” name=“BigFix CustomC” installed=“true”></EF:Application><EF:Application type=“AVApp” name=“Sophos Anti-Virus 9.7 AVApp” installed=“true”></EF:Application><EF:Application type=“Domain Security Applications” name=“HO - Domain Logon Check Domain Security ApplicationsC” installed=“true”></EF:Application></EF:CurrentAssessment>
T: 0.248 ms
Im Confused …Anyone can help ? …
