Help on BigFix Relay
Good morning,
I have a small BigFix infrastructure with 230 workstations. The structure is divided into 27 locations and to optimize network traffic I have promoted a computer Ralay at every location. All notebooks are forced to keep all clients in “automatic select” except relays that point directly to the BigFix Server.
My problem is this:
I DO NOT want that branches speak with each other, they should get the local relay, if it is on, or the server only
I really like the logic of this fixlet/task:
https://www.bigfix.me/fixlet/details/3916
setting “_BESClient_Register_Affiliation_SeekList” = “{registration subnet address of client as string}; PrimarySite; *” on “{now}” for client
but unfortunately it does not work. It only recognizes PrimarySite and * but not local relays.
I used BESRelayRegister_Affiliation_AdvertisementList on BigFix Server to assign the label.
any idea?
Thanks for your help
Allan
Looks like you may be missing the leading _ on the setting? Have you confirmed the advertisement list on your relay is actually what your clients expect it to be?
_BESRelay_Register_Affiliation_AdvertisementList
I would also add that after you update relays (including creating or deleting relays, or updating their Advertisement Lists), you must also take at least one action as a Master Operator. The relays.dat file that clients use to lookup relays is part of the actionsite, and you need to take a MO action to update the actionsite. That will trigger clients to gather and find the new relays.dat file.
This action should be dynamically targetted to ensure it’s created in the actionsite and not in a particular endpoints mailboxsite.
I do not believe that is the case anymore. The root server should self-propagate the actionsite for relays.dat changes.
the syntax is correct with _
only client have:
with value PrimarySite
all client have:
_BESClientRegister_Affiliation_SeekList" = “{registration subnet address of client as string}; PrimarySite; *” on “{now}” for client
I have adopted a workaround, but i dont like it this solution. I closed port 52311 between sites/branch.
I look for an alternative solution :slight_smile:
Are you allowing ICMP to the relays? A client will not autoselect a relay unless it answers to ICMP first; and the client should select the relay with the lowest hop-count (within its AffiliationSeekList, if set).
If I’m understanding this correctly, you are saying that the Relay at the site has the “PrimarySite” as the _BESRelay_Register_Affiliation_AdvertisementList setting? If so, that is the problem.
Assuming one of your sites has the subnet address 10.10.10.0, you should have on all the clients at that site:
_BESClient_Register_Affiliation_SeekList = 10.10.10.0;PrimarySite;*
At that same site, you should also have set (only on the Relay):
_BESRelay_Register_Affiliation_AdvertisementList = 10.10.10.0
And on the Relay (or Server) which represents the “PrimarySite” (at a minimum)
_BESRelay_Register_Affiliation_AdvertisementList = PrimarySite
