Help Installing Web Reports After Initial BigFix Server Setup
Hello everyone,
I’m encountering an issue with a new BigFix installation.
During the initial setup, I installed the BigFix Server but chose to skip the Web Reports component. Now, I’d like to install Web Reports on the same server, but I keep running into a problem: the installer reports that the Server (Root Server, for I’m using installation generator) is already installed and won’t proceed.
Has anyone successfully installed Web Reports as a standalone component after the main server installation? If so, could you share the steps or any workarounds?
**Yes, it also doesn’t work when I download only the server installer.
Thanks in advance for your help!
