Hello i need help to clean up the data base
Hi,i need help to clean up the tem data base, because the server when it is installed the tool, please help.
Not sure what you are looking for. why do you need to “clean up the TEM database”?
If your referring to maintenance tasks for the database, there are a couple of BigFix tools available that can help. There’s the BESComputerRemover.exe, and BESAuditTrailCleaner.exe, both of which you can find on IBM developer works under Utilities:
You can use the computer remover to remove expired computers and duplicated from your database, and the audit trail cleaner is for expired BigFix content.
I would highly recommend that you back up your database before running the utilities.
https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/Utilities
