Since our WebReport been upgrade to IBM version, the CSV files in exported had a strange behavior, in the old version the character for every column using comma and when in one column having mulitple value, it’s used semicolon
But in the new version, for multiple value, it use character enter, so when it display using notepad the information is absurd
Example for the old version :
“”“A000C-ACC192"”",""“1280 MB”"",""“slamet001900"”",""“ST380013AS”"; ““Kingston DataTraveler G3 USB Device””",""“False”""
The reason for this change was to fix a bug. The problem was that results could have semi-colons, which means it was a bad delimiter.
The new format is still compliant with CSV and it should open up fine in Excel.
It is pretty ugly in a text viewer, but you might consider using the Excel Connector to get the info you want in a pretty way (and I think it has options for the multiple result format):
