General transport failure
(imported topic written by sgreenwall91)
We are seeing an increased number of clients that are not able to synchronize with their server. The local log file on the PCs shows:
At 15:18:19 -0700 - actionsite (http://:52311/cgi-bin/bfgather.exe/actionsite)
Failed downloading ‘http://:52311/bfsites/actionsite_4469/__diffsite4467’
FAILED to Synchronize - General transport failure. - ‘http://:52311/bfmirror/bfsites/enterprisemirror_1_4469/__diffsite4467’ http failure code 404
Where “” is the actual name of our server. This entry occurs repeatedly and all actions pending for the system in the console sit with “” showing.
Anyone have a solution?
Hi sgreenwall,
A 404 failure usually indicates that the computer isn’t able to resolve the . Could you try pinging this alias from a computer with the failures? It could be a DNS issue if you are using a DNS alias for the BES Server.
If the ping is successful, try copying the full url (http://:52311/cgi-bin/bfgather.exe/actionsite) into internet explorer on the box and see if that resolves or not.
If the url fails, your BES Server likely isn’t propagating the actionsite correctly for some reason. Support should be able to help you figure out what is going wrong, you may want to raise a support call.
Talking with support… if the BES Server runs out of disk space it won’t be able to create the latest versions of the actionsite and the BES Clients will receive 404 errors trying to gather the non-existent data. Try clearing up disk space and then take a new action to propagate the actionsite.
