Flash Player Activex versus Flash Player Plug-in
(imported topic written by jr6591)
For flash player upgrades, there are 2 components. 1 is the flash player active x and 1 is the flash player plugin.
Activex file name:
install_flash_player_10_active_x.msi
Plug-in file name:
install_flash_player_10_plugin.msi
The fixlet available in BES is this one: install_flash_player_10_active_x.msi
This will upadate the activex but not the plug-in and not install the plug-in if the plug-in is not installed.
If you run this: install_flash_player_10_plugin.msi - it will update the plu-in.
So, is there a fixlet that does both? the current fixlet in BES does not upgrade/install both and therefore, there can be situations where you have version 10 of activex and version 9 of the flash player plug-in.
Any one seeing this as well?
