The latest flash player version doesn’t appear to be a security update; it only contains bugfixes and enhancements. The latest version in TEM is the last security update for Flash Player.
So is the official stance from IBM that they only publish updates for Adobe Flash Player if they are security related? I believe that I’m currently unable to deploy the flash plugin, because the size and sha1 no longer match. It’s downloading the latest version from Adobe, and that is newer than the one in the fixlet, so it fails.
Just an update that this has been corrected in the TEM Console. Version 11.3.300.262 is now in the title, and the sha1 has been updated so the fixlet completes successfully now.
