I had a baselines with certain patches which was run on Server A and B. The baseline completed and actions took place. I can see the action history on the console as well as web reports. But when i check the results for the patch fixlet on web reports, server A does not show up as remediated or relevant. So when i try to pull the patch report for the servers, only server B shows up as remediated but server A does not show up at all.
How would i go about debugging this issue? Is there a way to have the server re-report its results?
For Server A, is it possible that its Computer ID changed since the baseline action was run?
No, the computer id did not change. I crossed check the action history of the baseline and its the same computer id that is there now.
In that case, did Server A ever show relevant for any of the source Fixlets or components of the baseline prior to executing the baseline action?
