(imported topic written by Bhushan_Chirmade)
I got site id 2148485324 using below query:
id of bes sites whose (name of it = “ActionSite”)
I am trying to execute following code segment to load the fixlet:
siteId = 2148485324
Set fixlet = CreateObject(“BESAPI.FixletMessage”)
fixlet.Load siteId,fixletId, username, password
WScript.Echo fixlet.DiagnosticMessage
WScript.Echo fixlet.name
All the time I keep getting overflow error. I tried to use vbscript CLng function however the value is is out of range for long integer. I tried to convert the number into negative unsigned number as -2146481972 and this time it accepted it but got database error as below:
Database Error: A database query unexpectedly failed to return any results.
I am not sure what next step and where to check for any additional logs. Isn’t vbscript is right way for using Bigfix API? Why the site id created is not in long integer range?
Regards,
Bhushan
