I have created the below fixlet but the task is still running, also checked C:\Program Files (x86)\BigFix Enterprise\BES Client__BESData__Global__Cache\Downloads and find there are data downloaded.Please advice
prefetch 5aa4687299e2e8461cedd60e26bf924dd86f365b sha1:5aa4687299e2e8461cedd60e26bf924dd86f365b size:85841402 http://sharename:52311/Uploads/5aa4687299e2e8461cedd60e26bf924dd86f365b/jre-8u351-windows-x64.exe.tmp sha256:0c04c3eebcd9c80d253b3dabe7a195d34f24b46959e861330bbf2dca2b7c48fc
extract 5aa4687299e2e8461cedd60e26bf924dd86f365b
wait __Download\jre-8u351-windows-x64.exe
continue if {not exists running application whose ((it = “java.exe” OR it = “javaw.exe” OR it = “javaws.exe” OR it = “iexplore.exe” OR it = “firefox.exe”) of (name of it as lowercase))}
// Note: update .exe will restart service automatically
if{exists running service “JavaQuickStarterService”}
delete __appendfile
delete stop_javaquickstarter.bat
appendfile net stop JavaQuickStarterService
move __appendfile stop_javaquickstarter.bat
waithidden stop_javaquickstarter.bat
endif
delete __appendfile
appendfile @ECHO OFF
appendfile {concatenation “%0d%0a” of (“start /w msiexec /x” & name of it & " /qn REBOOT=ReallySuppress") of keys whose (((it contains “java” OR it contains “j2se”) AND NOT (it contains “development kit” or it contains “auto updater” or it contains “javafx” or it contains “db” or it contains “sdk”)) of (value “DisplayName” of it as string as lowercase) AND value “DisplayVersion” of it as string as version >= “1.4.2” AND (exists value “Publisher” whose (it as string as lowercase contains “oracle” or it as string as lowercase contains “sun”) of it) AND (numeric value of concatenation of (if length of it = 1 then “000” & it else if length of it = 2 then “00” & it else if length of it = 3 then “0” & it else it) of substrings separated by “" of substrings separated by “.” of ((pad of (value “DisplayVersion” of it as string as version)) as string)) < (maximum of (numeric values of concatenation of (if length of it = 1 then “000” & it else if length of it = 2 then “00” & it else if length of it = 3 then “0” & it else it) of substrings separated by "” of substrings separated by “.” of ((pad of (value “DisplayVersion” of it as string as version)) as string)) of keys whose (((it contains “java” OR it contains “j2se”) AND NOT (it contains “development kit” or it contains “auto updater” or it contains “javafx” or it contains “db” or it contains “sdk”)) of (value “DisplayName” of it as string as lowercase) AND value “DisplayVersion” of it as string as version >= “1.4.2” AND (exists value “Publisher” whose (it as string as lowercase contains “oracle” or it as string as lowercase contains “sun”) of it)) of key “HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall” of registry)) of key “HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall” of registry}
//delete uninstallJRE.bat
//copy __appendfile uninstallJRE.bat
//wait “{pathname of client folder of site “BESSupport”}\RunQuiet.exe” uninstallJRE.bat
//Java 8 u 261 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180191F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180201F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180211F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180221F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180231F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180241F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180251F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180261F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180271F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180191F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180201F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180211F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180221F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180231F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180241F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180251F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180261F0} /qn /norestart
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F64180271F0} /qn /norestart
//Java 8 u 241 Removal
//Java 8 u 281 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180281F0} /qn /norestart
//Java 8 u 291 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180291F0} /qn /norestart
//Java 8 u 301 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180301F0} /qn /norestart
//Java 8 u 311 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180311F0} /qn /norestart
//Java 8 u 321 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180321F0} /qn /norestart
//Java 8 u 331 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180331F0} /qn /norestart
//Java 8 Update 333 (64-bit)
waithidden MsiExec.exe /x {{26A24AE4-039D-4CA4-87B4-2F64180333F0} /qn /norestart
//Java 8 u 341 Removal
waithidden MsiExec.exe /X{{26A24AE4-039D-4CA4-87B4-2F32180341F0} /qn /norestart
//Java SE Development Kit 8 Update 341 (64-bit)
waithidden MsiExec.exe /x {{64A3A4F4-B792-11D6-A78A-00B0D0180341} /qn norestart
