Fixlet for USB block for Linux
Dear All,
Can anyone, please share your feedback to create a fixlet script for the below shell script
  • /bin/bash -c “echo blacklist usb_storage >> /etc/modeprobe.d/blacklist.conf”
wait /bin/bash -c “echo blacklist usb_storage >> /etc/modeprobe.d/blacklist.conf”
I am getting “The operator “wait” is not defined” if i execute the above script.
If you are changing the script type to sh, you should not need wait.
Try just this:
thanks you so much, jgo…
Or You can make download that script using prefetch and run with bash ./filename.
