Fixlet Debugger QNA not showing results
Is anyone else having the issue of QnA in the fixlet debugger not showing any answers? I’m using 9.5.8.38 installed with the console. single clause and graphical seem to be working. I also downloaded a fresh copy from the release website and the qna.exe app works as expected but when I try the same query “current date” in the debugger nothing is provided as an answer.
If its an issue I can open a support ticket.
A screenshot would be helpful.
You’re missing the Q:
Capture
Thanks. I always forget about having to add the Q:
