Hi there,
I have created a test fixlet in the Bigfix console (using the Software distribution wizard;task is to input files into specific folder in the laptops), but apparently I am not able to find the fixlet in the WebUI. Is there a way for the webui to use the fixlet that was created in the console?
Using Webui, is the below correct to place files in the specific folder in the endpoints?
Appreciate your response. Thanks!
