Fixlet Authoring and Wizard
(imported topic written by jr6591)
It would be a good idea if that in the Wizard, you were able to select Retrieved properties from a drop down list as opposed to creating them again (ie. select one or multiple properties and then have them populated in the fixlet relevance.
Also, the wizard should have more features such such giving you the ability to have multiple command lines. Currently you can do that but in the Edit screen.
