I ran into some issues setting up a CentOS / RHEL / Fedora relay recently.
Turns out on the newest version, there is both IPTables and Firewall-Cmd that need to be set.
iptables -A INPUT -p tcp --dport 52311 -j ACCEPT
iptables -A INPUT -p udp --dport 52311 -j ACCEPT
firewall-cmd --zone=public --add-port=52311/tcp --permanent
firewall-cmd --zone=public --add-port=52311/udp --permanent
It would be nice if there was a bigfix fixlet that detected the missing firewall-cmd’s and would add them when run.
Related:
- http://stackoverflow.com/questions/24729024/centos-7-open-firewall-port
- http://wiki.centos.org/HowTos/Network/IPTables
- http://www-01.ibm.com/support/docview.wss?uid=swg21505873
- https://www.ibm.com/developerworks/community/wikis/home?lang=en#/wiki/Tivoli%20Endpoint%20Manager/page/Log%20Files
- http://support.bigfix.com/bes/release/
- http://support.bigfix.com/bes/release/9.2/patch1/
- http://support.bigfix.com/bes/install/besclients-nonwindows.html#centOS
- https://danielmiessler.com/study/fedora_redhat_centos/
- https://access.redhat.com/sites/default/files/attachments/rh_yum_cheatsheet_1214_jcs_print-1.pdf
- http://www-01.ibm.com/support/docview.wss?uid=swg21505838
- http://www-01.ibm.com/support/docview.wss?uid=swg21506065
- http://www-01.ibm.com/support/docview.wss?uid=swg21506050
- http://www.cyberciti.biz/faq/rhel-redhat-centos-7-change-hostname-command/#1
- https://www.ibm.com/developerworks/community/wikis/home?lang=en#/wiki/Tivoli%20Endpoint%20Manager/page/Configuration%20Settings
The complete instructions: (as root)
yum install wget -y
wget http://__RELAY_OR_ROOTSERVER__:52311/masthead/masthead.afxm
mkdir /etc/opt/BESClient/
cp masthead.afxm /etc/opt/BESClient/actionsite.afxm
wget http://software.bigfix.com/download/bes/92/BESAgent-9.2.6.94-rhe5.x86_64.rpm
rpm -ivh BESAgent-9.2.6.94-rhe5.x86_64.rpm
wget http://software.bigfix.com/download/bes/92/BESRelay-9.2.6.94-rhe5.x86_64.rpm
rpm -ivh BESRelay-9.2.6.94-rhe5.x86_64.rpm
Will require tweaking when newer client/relay is released. May also require tweaking for the zone for the firewall-cmd
