Hi, just thought that I would bring to your attention…
I was just trying to creating a Web Report and one of the filters was Content -> Source Release Date -> is -> date
If you use the pop-up calendar to select a date, it enters the date in the field as mm/dd/yyyy. However, the Source Release Date for my fixlets is in the format dd/mm/yyyy therefore it doesn’t find the correct fixlets.
I tried typing the date in by hand which doesn’t seem to work either and selecting 9th Feb 2010 to retrieve fixlets from the 02nd September 2010 sometimes works but not always.
I meant the Source Release Date as reported in the Bigfix console for any fixlet, task, etc.
I’ve attached a couple of screenshots (hopefully). In the Web Reports screenshot, I selected the date by clicking in the date field and then selecting the 13th September from the dropdown calendar.
