We are noticing what appears to be a false positive in MS15-116, KB3085561. Machines are reporting the update as missing yet the patch cannot be installed as it reports it is already installed on the system. This seems to be due to the relevance is using the older style detection logic and is looking explicitly for the patch GUID for KB3085561 but the update has actually been applied by the December non-security update KB3114329 which also has newer files than those in KB3085561.
Can fixlet 1511565 be updated to use the logic that caters for this scenario? It look like fixlet 1511623 for the 64 bit version of KB3085561 already contains the logic to cater for this scenario.
The fixlet appears to correct the false positive. Several machines showing relevant for the current fixlet are not showing relevant for this custom fixlet.
hello i am on the latest site version but it appears i have a machine still having this issue with showing relevance and then error code returned when attempting to deploy the fixlet is that it is already installed yet it still shows relevance… any help?
Please contact IBM support and open a Salesforce ticket for your issue along with the following information:
client log with the error code you mentioned.
Export the installer key from the native registry of the affected machine:
“HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer” of native registry
