False positive, affecting but possible not limited to KB5003173
We are seeing a small number of false positives for KB5003173 but the root cause could well impact other fixlets.
Systems affected are 21H1 or 21H2 released that have been updated from 2009/20H2. As MS have deprecated the ReleasedID but do not remove that during the feature update, the legacy “ReleaseID” value in “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion” still exists as triggers a True on relevance 6 in fixlet 500317305, exists value "ReleaseID" whose (it as string = "2009") of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion" of native registry
In actual fact, the systems now have the new"Display Version" with a value of 21H1 or 21H2 but still have the deprecated "ReleasedID" value so causes a false positive.
Thank you @SLB. I will alert the content team of this post.
If you would like the support team to engage directly with you on this item and track it to closure then please open a ticket at support.bigfix.com.
@SLB relevance has been updated to use CurrentBuild
Fantastic. Thank you @brolly33 and the content team. You guys rock. :metal:
