Failed SOAP perl client "proxy: transport protocol not specified"
See my last post , Javascript example doesn’t work, So I tried the perl example script in R1.
So far, SOAP scripting with Bigfix is still no luck.
  1. here is my version of simple test script, it ended with error on Fedora14-32 OS.
root@t-fedora14-32 bigfix
./bf.pl mypassword
cat ./bf.pl
#! /usr/bin/perl
use SOAP::Lite;
#arguments:
password
my $host = “bfxreports.test.com”;
my $name = “addomain\account”;
my $pass = $ARGV[0];
my $RL = “number of bes computers”;
my $username = SOAP::Data->name(‘username’ => $name );
my $password = SOAP::Data->name(‘password’ => $ARGV[0] );
my $expr = SOAP::Data->name(‘relevanceExpr’ => $RL );
my $service = SOAP::Lite -> uri( ‘http://’ . $host . ‘/webreports?wsdl’ ) -> proxy( $host );
#my $service = SOAP::Lite -> uri( ‘http://’ . $host . ‘/webreports?wsdl’ ) ;
my $result = $service -> GetRelevanceResult( $expr, $username, $password );
if( $result->fault )
print "faultcode: " . $result->faultcode . “\n”;
print "faultstring: " . $result->faultstring . “\n”;
else {
foreach my $answer ( $result->valueof( “//GetRelevanceResultResponse/a” ) )
print $answer . “\n”;
  1. Here is the perl and SOAP::Lite version info.
root@fl36t-fedora14-32 bigfix
rpm -qa perl-SOAP-Lite
perl-SOAP-Lite-0.711-1.fc14.noarch
perl -v
This is perl 5, version 12, subversion 3 (v5.12.3) built for i386-linux-thread-multi
Copyright 1987-2010, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using “man perl” or “perldoc perl”. If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
R1: http://support.bigfix.com/product/documents/BigFix_Web_Reports_80_100810.pdf
I tested using SOAP from a Ubuntu box.
I get the same error you got “proxy: transport protocol not specified”.
With the following modification, I was able to connect correctly.
Changed the “my $service…” line to the following:
color=red
ns[/color]( ‘http://’ . $host . ‘/webreports?wsdl’ ) -> proxy(
color=red
‘http://’ .[/color] $host );
I think it has to do with newer version of the SOAP::Lite library.
A much better message then “proxy:transport protocol not specified”.
I embedded the password as string inside bf.pl
./bf.pl
faultcode: env:Client
faultstring: Invalid username or password.
Thanks Wei.
Need to play around to get authentication passed.
tj
Changed from
my $name = “domain\myaccount”;
to
./bf.pl
638
Thanks for Wei’s road block lifting.
tj
I know this is an old post, but I thought Id mention tjyang’s code works on Windows with Active State Perl (listed below) .
#! /usr/bin/perl
use SOAP::Lite;
#arguments:
password
my $host = “BFSERVER.FQDN.com”;
my $name = “username”;
my $service = SOAP::Lite -> ns( ‘http://’ . $host . ‘/webreports?wsdl’ ) -> proxy( ‘http://’ . $host );
else {
