Is there a way to extract the bfz and bfa files outside of the console?
I am looking to get the MSI/ EXE files that install the SIE (software isntallation Engine) and TRC (Tivoli Remote Control). I want to add these as software packages within TPMfOSD (standalone, not TEM intergrated).
Trying to find the specific downloads on the IBM site has been problematic, so I figured I can hit the link that is in the actions cript for the fixlets and get the package that way. However once I get that, Ineed to extract it outside of the console.
Usage instructions (taken from the usage string in the file itself):
bfarchive.exe -a
bfarchive.exe -a64
bfarchive.exe -x
To archive more than one file, you have to put all of them in a directory and archive the directory, since you cannot specify more than one file on the command line.
