I have attempted to reverse engineer the discovery of SQL Server by BFI, and it appears that certain Microsoft products have additional, under-the-covers discovery logic not found in the catalog data. These products’ signatures include the asterisk (*) rather than a GUID in the Registry Key exposed by the signature. Obviously, there is no Registry Key called DisplayNameVersion, so it must match on some other logic, which appears to be a product entry key, for example:
HKLM\SOFTWARE\Microsoft\Microsoft SQL Server\110\Tools\Setup
and a REG_SZ key:value pair:
Edition=Standard Edition
Which gets translated to Microsoft SQL Server 2012 Standard Edition in the discovery data.
The catalog signature data shows this explicitly for a SQL Server 2016 Evaluation Edition:
<Signature guid="f35d9bbd97947e2b8a96eb3c26806764" type="OtherSignature">
<MultipleInstance>
<Iterator export="false" name="rg">
<Vector>
<RegKeyList root="HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\MSSQL*" section="32or64"/>
</Vector>
</Iterator>
<Instance>
<Variable name="IS_INSTALLED">
<And>
<PackageInfoMatch vendor="*" name="Microsoft SQL Server 2016*" version="*"/>
<RegKeyValueContains entry="EditionType" key="$(rg)" section="32or64" value="Eval"/>
</And>
</Variable>
<Condition withVariable="IS_INSTALLED">
<Action do="SKIP" onValue="false"/>
</Condition>
</Instance>
</MultipleInstance>
</Signature>
