Hi All,
I am about to install application using task action script, and because I have to add some regedit also so I use task action script rather than Software Distribution,
This task will download .bat file and run it locally, because the required file already stored in the local drive
I the log it said "Exit Code =0"
ActionLogMessage: (action:230) Non-Distributed - DownloadsAvailable
ActionLogMessage: (action:230) Action signature verified for Execution
ActionLogMessage: (action:230) starting action
At 22:11:56 -0500 - actionsite (http://iemserver.training.tivoli.edu:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Using download manager collected file) download http://192.168.1.100:52311/Uploads/odfb_achmad.bat (action:230)
Command succeeded copy “__Download/odfb_achmad.bat” “C:\odfb_achmad.bat” (action:230)
Command started - wait “C:\odfb_achmad.bat” (action:230)
At 22:12:07 -0500 -
Report posted successfully
At 22:12:33 -0500 - actionsite (http://iemserver.training.tivoli.edu:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=0) wait “C:\odfb_achmad.bat” (action:230)
At 22:12:33 -0500 -
ActionLogMessage: (action:230) ending action
At 22:12:33 -0500 - mailboxsite (http://iemserver.training.tivoli.edu:52311/cgi-bin/bfgather.exe/mailboxsite8351253)
Not Relevant - OneDrive 2016 Achmad (fixlet:230)
At 22:13:06 -0500 -
Herewith the .bat file command
C:\onedrive\OneDriveSetup.exe /silent
In the Console it said completed but I can’t find any OneDrive application listed both in Start Menu and Control Panel.
If I double click the .bat file manually the installation will success,
Please advise,
Many Thanks
