Hi All,
I am trying to execute an Power shell which will stop the BES Client service, delete the BES Data and start the BES client service via BIgFix action script. The script that I am suing is as follows:-
# STOP BES client service
Stop-Service -Name BESClient -Force
# Delete the __BESData folder
Remove-Item -Path "C:\Program Files (x86)\BigFix Enterprise\BES Client\__BESData" -Recurse -Force
# Start the besclient.service
Start-Service -Name "BESClient"
BigFix Action script that I am using is as follows:-
prefetch EUC_Fix.ps1 sha1:e7fe5ff1fdc7c7d805e00dae5a05dda27ff21602 size:256 http://localhost:52311/Uploads/EUC_Fix.ps1 sha256:878d4a45a2ec531332c4819dd4974a9540a770d9b577652dd361513374123f7d
// Check if the folder exists
if {exists folder "c:\temp"}
// Delete the folder if it exists
folder delete "c:\temp"
endif
// Create the folder
folder create "c:\temp"
// Move ps1 file to c:/temp
move "__Download\EUC_Fix.ps1" "c:\temp\EUC_Fix.ps1"
waithidden {{ pathname of file ((it as string) of value "c:\temp\EUC_Fix.ps1" of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell" of native registry) } -File "c:\temp\EUC_Fix.ps1"
action uses wow64 redirection {x64 of operating system}
Execution error is shows as follows:-
Command failed (Thread execution failed (2)) waithidden { pathname of file ((it as string) of value “c:\temp\EUC_Fix.ps1” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell” of native registry) } -File “c:\temp\EUC_Fix.ps1” (action:3117852)
Can you please suggest if the execution of the PS script could be an issue.
Regards,
VT
