I have an issue removing a EXE install.
Using the code here allows me to generate the uninstall command for the Exe.
Fixlett Code :-
appendfile {( value “UninstallString” of it) of keys whose (value “DisplayName” of it as string contains “SAP Secure Login”) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of (x64 registries;x32 registries)} /Silent
delete c:\windows\temp\SAP-Secure-Login.bat
copy __appendfile c:\windows\temp\SAP-Secure-Login.bat
waithidden cmd.exe /c “c:\windows\temp\SAP-Secure-Login.bat”
Result :-
“C:\Program Files (x86)\SAP\SAPsetup\setup\NwSapSetup.exe” /Product=“SLC” /uninstall /Silent
Fixlett - Failed with Exit Code 3 (Unable to start Windows installer error “3 the system cannot find the path specified”)
Bes logs … __Global\Logs show :-
Command started - waithidden cmd.exe /c “c:\windows\temp\SAP-Secure-Login.bat” (action:127600)
Command succeeded (Exit Code=3) waithidden cmd.exe /c “c:\windows\temp\SAP-Secure-Login.bat” (action:127600)
If I add in the wow64 redirection :-
action uses wow64 redirection true
But the same Failed with Exit Code 3 shown.
