Hi
Im trying to create a manual group but i get this message
someone have an idea how solve it ?
Hi
Sounds like your database is out of space. Is your SQL Server’s hard drive out of space? Have you changed the settings on the BFEnterprise database (by default it should grow automatically until you run short on drive space)?
Hi JasonWlaker, i found the source of the problem, i insatalled the SQL server express edition and this version has a limted size in the DB(10 GB), and the BFEnterprise DB it’s in 9.9 GB, so that is the problem.
the question now is, if there a possibility to migrate the sql server express edition to standard edition?
