I’m not sure if this is an problem within version 8 or whether the actionscript parser has always had this problem.
I was creating a task with an actionscript that was, basically:-
delete “__appendfile”
delete “fim_check”
createfile until END_OF_SCRIPT
bunch of shell script lines
END_OF_SCRIPT
move __appendfile ./fim_check
chmod +x ./fim_check
run sh ./fim_check
There is an error in my actionscript (the ‘chmod’ bit) that gets picked up by the parser when I try and save the task but the error message displays the error as being on line 0 (see attached file Error_1 )
If I comment out all the lines from the createfile to the END_OF_SCRIPT, inclusive, it correctly tells me the the error is on line 88 (see attached file Error_2).
