Attempting To Process a “sh” script through Big Fix Console.
Create Action as Follows:
wait rm -rf /tmp/bigfix_scripts
wait mkdir -p /tmp/bigfix_scripts/
move __Download/upgrade_7205sp2_v2.bff /tmp/bigfix_scripts/upgrade_7205sp2_v2.sh
continue if { exists file “/tmp/bigfix_scripts/upgrade_7205sp2_v2.sh” }
wait “/bin/sh” -c "chmod +x /tmp/bigfix_scripts/upgrade_7205sp2_v2.sh"
wait “/bin/sh” -c "/tmp/bigfix_scripts/upgrade_7205sp2_v2.sh"
parameter “Exitcode” = "{if exist exit code of action then exit code of action as string else “0”}"
if {parameter “Exitcode” != “0”}
exit 1
endif
Getting Results as Follows:
Command started - wait rm -rf /tmp/bigfix_scripts (action:9193)
Command succeeded (Exit Code=0) wait rm -rf /tmp/bigfix_scripts (action:9193)
Command started - wait mkdir -p /tmp/bigfix_scripts/ (action:9193)
Command succeeded (Exit Code=0) wait mkdir -p /tmp/bigfix_scripts/ (action:9193)
Command succeeded move __Download/upgrade_7205sp2_v2.bff /tmp/bigfix_scripts/upgrade_7205sp2_v2.sh (action:9193)
Command succeeded (evaluated true) continue if { exists file “/tmp/bigfix_scripts/upgrade_7205sp2_v2.sh” } (action:9193)
Command started - wait “/bin/sh” -c “chmod 755 /tmp/bigfix_scripts/upgrade_7205sp2_v2.sh” (action:9193)
Command succeeded (Exit Code=0) wait “/bin/sh” -c “chmod 755 /tmp/bigfix_scripts/upgrade_7205sp2_v2.sh” (action:9193)
Command started - wait “/bin/sh” -c “/tmp/bigfix_scripts/upgrade_7205sp2_v2.sh” (action:9193)
At 12:06:17 -0400 - actionsite (http://urmcbigfix.urmc-sh.rochester.edu:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=1) wait “/bin/sh” -c “/tmp/bigfix_scripts/upgrade_7205sp2_v2.sh” (action:9193)
Command succeeded parameter “Exitcode” = “1” (action:9193)
Command succeeded (1) exit 1 (action:9193)
