No exist fix of itic for this version.
Itic give me error :
30 mar 2017 17:22:53:478 [DEBUG] SQL:SELECT op.intvalue,op.strvalue,op.textvalue,p.name,p.type,op.oid FROM dbo.fsnobjproperty op,dbo.fsnproperty p WHERE p.cid=1 AND p.iskey=1 AND op.pid=p.pid ORDER BY op.oid,p.name
30 mar 2017 17:22:53:494 [DEBUG] 31 rows returned
30 mar 2017 17:22:53:494 [DEBUG] SQL: SELECT op.intvalue,op.strvalue,op.textvalue,p.name,p.type FROM dbo.fsnobjproperty op,dbo.fsnproperty p,dbo.fsnobject o WHERE op.pid=p.pid AND p.cid = ? AND o.cid=p.cid AND o.oid=op.oid AND op.oid = ?
30 mar 2017 17:22:53:494 [DEBUG] Values: |1=1|2=41|
30 mar 2017 17:22:53:494 [DEBUG] 9 rows returned
30 mar 2017 17:22:53:557 [ERROR]
Error Message: Internal error
Connection failed. Please check the URL.
Error trace:
com.mro.fusion.dbInterface.temsua.TEMSUAConnection.getToken(TEMSUAConnection.java:1895)
com.mro.fusion.dbInterface.temsua.TEMSUAConnection.openDataSource(TEMSUAConnection.java:1583)
com.mro.fusion.om.DataSource.openConnection(DataSource.java:681)
com.mro.fusion.om.ObjectManager.connect(ObjectManager.java:524)
com.mro.fusion.om.ObjectManager.connect(ObjectManager.java:321)
com.mro.fusion.engine.EngDataSource.connect(EngDataSource.java:371)
com.mro.fusion.engine.EngineMain.setSourceDataSource(EngineMain.java:1074)
com.mro.fusion.engine.EngineMain.initialize(EngineMain.java:1812)
com.mro.fusion.engine.EngineMain.(EngineMain.java:233)
com.mro.fusion.engine.EngineMain.doMain(EngineMain.java:573)
com.mro.fusion.engine.EngineMain.main(EngineMain.java:422)
30 mar 2017 17:22:53:557 [FATAL] Error(s) encountered.
Error Message: Database connection failed
See log file for details.
Operation failed on: Mapping: 11-11–11, Source data source: 11
Error trace:
com.mro.fusion.engine.EngineMain.setSourceDataSource(EngineMain.java:1079)
30 mar 2017 17:22:53:557 [FATAL] Mapping execution terminated.
